Travel
04-10-2024
01:54 AM
05-11-2024
10:45 AM
Dunkman
04-10-2024 10:44 AM
Get a travel esim from Airalo or Ubigi.
04-10-2024 07:29 AM
@Cenk PM does not offer service outside of the US and Canada. If you travel a lot, you might want to consider going to a carrier that does - but trying to change Canadian cell plans while outside of the country is going to be difficult (e.g. to port your number you would need to reply to a text from your PM account, but that won't work because you don't have service). It might be something to consider when you return to Canada.
Instead, as others have mentioned, your option is to buy a local SIM or eSIM from a Mexican provider. Depending on what you buy, that may get you just data or it may get you calling and texting as well - albeit on a Mexican number. And of course, you can always use a voice over data service like WhatApp or FaceTime to make calls - but that really only works if the people/organizations you need to call also use the same service.
There really isn't going to be any way to get calling/texting on your PM phone number, unfortunately.
04-10-2024 07:23 AM
@spitre78 Since PM does not offer any service outside of Canada or the US, there's no point in talking to customer service.
04-10-2024 07:09 AM
As previously stated you could get a local Sim or if phone allows an eSim but try customer service and see if there's a roaming plan that includes Mexico
04-10-2024 03:29 AM
You have several options:
- purchase a local SIM
- use Whatsapps or TextNow app for free calling and texting on wifi
04-10-2024 01:59 AM
@Cenk wrote:Hi I just arrived to Mexico and i cant use my data. What should i do?
Sorry, but there is no Public Mobile service available in Mexico. You'll have to use Wi-Fi or the service of another cell phone company.
