Previous carrier's VM is still on my phone after porting my number yesterday
04-10-2024
10:05 AM
04-10-2024
10:13 AM
Dunkman
I am now a member of Public Mobile - the phone does work for outgoing calls, and it does say Public Mobile on the top right of my phone screen. PROBLEM: my previous carrier, virgin mobile, still has a voicemail on my number and it is intercepting all of my incoming calls - my phone goes straight to THEIR voicemail... My number is 1-613-xxx-xxxx and I am brand new here as of yesterday.
Edit: removed personal information
Joining Public
My Account
04-10-2024 10:13 AM
HI @Robert2024
the text issue is another problem that PM current has with new activation. They can fix that text issue. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
04-10-2024 10:12 AM
I cannot text either - just checked. Ok I will look for that number
04-10-2024 10:11 AM
Are you able to receive texts in your original VM number?
If not, then your porting was not processed properly. Did you respond "yes" to VM's port request text?
I will private message you the Telus team porting team number. They can check the status of the port.
04-10-2024 10:10 AM
HI @Robert2024
Did you get a text from the old carrier, did you reply YES?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
