05-25-2024
10:45 AM
05-25-2024
11:51 AM
computergeek541
I created an account and selected to transfer an existing number, which is a landline number.
During the transfer process, a verification code is sent to the landline number, which cannot receive messages, so I'm stuck.
When I try to access my Public Mobile account, a verification code is sent again to the landline number, again, I cannot receive messages to the landline number.
05-28-2024 02:04 PM
thanks for the update @crocobaur
yes, trasnfer from landline takes a bit longer. 4 calendar days is the average time, some had it as long as 7 working days
05-28-2024 02:03 PM
Update:
The landline number was transferred in 4 calendar days (2 business days).
I can send/receive text messages and I get 2fa/mfa codes as text.
05-25-2024 03:07 PM
So landlines can receive 2fa but it normal comes a voice message that you need to enter on what ever device that need the code. They can also receive text as well it gets converted to ai speech.But it all depends on who sending the 2fa request or text. Also once a bell landline is transferred to a cell it becomes a cell number in its own right. As I have one from bell now and have not run into any restrictions from it being originally a landline. Can send a receive text and receive 2fa by text as well. So I don't see them having a problem one it's up and running.
05-25-2024 12:46 PM
@crocobaur wrote:@YummyI don't understand what you mean. After the number is transferred, it will be on a cell phone, so I assume I will be able to receive SMS messages.
Phone number being on mobile does not mean it will be 'mobile number'.
Here is an example:
This is REAL land line:
This is Bell MOBILE:
Companies sending 2FA will recognize 905-882-xxxx as land line and will not send 2FA on that number.
Companies sending 2FA will recognize 905-236-xxxx as MOBILE number and Will send 2FA to it.
So far I did not hear opposite - that your 'land number' transferred to mobile device can receive 2FA thus I am holding my land line porting to PM.
05-25-2024 11:23 AM
Have you tried the SIM card in another phone? Not for the transfer reasons but to @Dunkman point of making sure the service works first with a temporary number. If you have a spare phone or someone you can borrow a phone from for a few minutes, turn off the phone, insert SIM, reboot.
05-25-2024 11:19 AM
05-25-2024 11:14 AM
Are you 100% you will be able to receive 2FA in the future on your mobile device having land line number???
05-25-2024 11:07 AM
@crocobaur wrote:@DunkmanThank you for your answers.
I rebooted the phone and still no service.
I already tried to contact a customer service agent and that seems to be a chatbot service that only replies with precooked answers. Is there a way to contact a customer service human agent?
If the ticketing system is not working, send a private message to CSA through the following link :
You can ask customer service agent if they can set up a temporary number, etc.
05-25-2024 11:04 AM
Is there a way to go back and activate my account with a temporary number?
05-25-2024 11:03 AM
@RastinThank you for your answer. I'm worried because I could not finish the transfer process, so the account doesn't seem to be activated. But I cannot check anything, because I can't receive that verification code on the landline number.
05-25-2024 11:01 AM
05-25-2024 10:59 AM
Usually, I would recommend a new customer activate a new temporary phone number with Public mobile. Get the service working. Then via the self service account request a landline port. As your wait for the port to be completed (ie. several days), at least the customer will have some mobile service with the temp number.
05-25-2024 10:56 AM
Land lines take about 5 days to transfer. When I did it it took bell 4 days to call me to approve the transfer and 1 more to do it.
05-25-2024 10:54 AM
Try to reboot the phone and see if any service.
If not, you will need to contact customer service agent to check status of account and port.
05-25-2024 10:50 AM
I used a physical SIM card. It's in the phone and I don't have any service.
05-25-2024 10:47 AM
From my understanding, landlines transfer do not need a verification code since landlines can't receive texts. However, landlines do take several days for the port to be completed. Mobile line transfers take up to a few hours, but landline/VoiP lines take several days.
Did you activate a physical SIM or eSIM? If physical card, try to insert into your phone to see if any service.
05-25-2024 10:46 AM - edited 05-25-2024 10:50 AM
Hello.
First find out if the number is eligible to move.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
If it is, please create a ticket to transfer it over.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
