02-28-2023 08:17 PM
I tried transferring my phone number to my new SIM card but it said the transfer didn't work. Now when I enter my number to try again it says to enter a Canadian number that exists. What do I do?
02-28-2023 08:21 PM - edited 02-28-2023 08:22 PM
@dysyevi you are exiting customer? if so, you don't go to activate portal to activate
you login to My Account using a computer only, the click Change sim card from the quick links menu and follow the steps:
02-28-2023 08:21 PM
@dysyevi Check to see that number can be transferred
Check to see if # can be ported
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
