Outgoing call I did not make
02-28-2023 03:52 PM - edited 02-28-2023 07:45 PM
There is an outgoing call to 1 (825) 439-xxxx I did not make and it used up my minutes. Any idea how what may have happened?
My Account
02-28-2023 07:46 PM
Thanks, good advice.
02-28-2023 05:51 PM
@chansimons2007 remove the number if that is your daughter's number. You dont want to many people call and check. Go back to the post, click down arrow and Edit Message
02-28-2023 05:49 PM
@chansimons2007 yup, it is AB area code. I tried to call but not connecting myself LoL
Happy that this is now sorted
02-28-2023 05:48 PM
Looks like 587, 825, and 368 are all Alberta area codes. I was not aware of this and that explains things. This is my daughter's phone and I thought a strange long distance number is showing up. Sorry for the confusion.
02-28-2023 05:18 PM
Pocket dialling isn’t always a number in directory. Random buttons can be pushed in pocket and send button then hit while still in pocket.
02-28-2023 04:02 PM
@chansimons2007 check your call log on your phone as well to see if you can find the 2 calls and if match the time / date showed on PM
Also, it could be app as well. Really restrict that access right for apps
02-28-2023 04:00 PM
If I do not know that number, how do I pocket dial it? 😐
02-28-2023 03:58 PM
My phone history on Public Mobile says it used 2 outgoing calls 30 sec and 31 sec. That is nothing, but I am concerned that there is an unknown number using my minutes.
02-28-2023 03:58 PM
@chansimons2007 Could it be possible you pocket dialled it by accident .. ?
02-28-2023 03:57 PM
@chansimons2007 cannot find any info on this number.
How many minutes it used? Check your call log on your phone and see if you can find it there
