03-03-2024 06:18 PM
Hi! Just transferred from rogers onto public. I can send texts and make calls but not receive texts or calls, it said the transfer was complete. I have restarted my phone and no luck. Thanks for any help!
03-03-2024 06:32 PM - edited 03-03-2024 06:34 PM
@Riceball Check your sim manger do you see esim for PM ? If so make sure it’s enabled or set to primary and reboot the phone maybe it already installed and the ports complete
add but if you need support
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support to fix
send a private message To CS_Agents
03-03-2024 06:23 PM
My old SIM got overridden when I transferred, (it was also an eSIM). How should I handle this?
03-03-2024 06:21 PM
Did you reply to the text with YES with the old SIM in your phone within the 90 minute window?
This is the most critical step in completing the porting of your old number.
03-03-2024 06:20 PM
@Riceball Did you leave old providers sim in the phone to reply YES to the confirmation text ? I’ll send you the porting team number private message . They ca re trigger the port request for you
