Transfer subscription
joshi1
I would like to transfer my paid subscription to my physical sim. My current phone is not e sim compatible and i already paid for the subscription. I have a physical sim now, I need help transfer the service.
@joshi1 wrote:
I am a new customer so i do not have access to the profile section. The application shows that i have an incomplete esim registration. Nothing else.
@joshi1
Then you will need to contact customer service agent.
Send a private message to CSA through the following link :
Expect 1-2 hour wait time for response.
joshi1
DashiellQwerty
If you have the app on your phone, you can go to Account>Change your Sim Card>Enter your 19 Digit Sim Card>Click Change Sim Card
Dunkman
@joshi1
More details would be helpful.
Are you a new customer who just activated an eSIM, but your phone is not compatible?  Now are you trying to switch to physical SIM card?
Or are you an existing customer with an eSIM phone?  Now want to switch to physical SIM card?
@joshi1  If your able to log into your account just go to profile and sim swap the number . If you can’t log into get support to sim swap the number for you
send  a  private message   To CS_Agent
HALIMACS
@joshi1  Log into your self-serve account and go onto your Profile tab and there you can update the associated SIM card.
if you’re unable to receive a two factor authentication code, tap “didn’t get the code?” and have it sent to the associated email for the account
