02-06-2022
04:26 PM
02-06-2022
05:56 PM
computergeek541
Hello,
I accidentally typed the wrong TN during the transfer and the transfer went through. How do I correct it? I can't change the TN in self serve.
Thanks
02-06-2022 06:19 PM
@Mdhatt1942 If it's too late to stop the transfer you could transfer that number back to your original carrier, then open a new account with PM and transfer correct account to PM. You only be out the cost of activating the first account.
Of course, you could also just open a second PM account (giving yourself a referral), transfer your other number to PM. Just remember that each active PM account must have its own email address.
02-06-2022 04:33 PM - edited 02-06-2022 04:34 PM
@Mdhatt1942 wrote:Hello,
Thanks
@Mdhatt1942 - was this a cell phone transfer? If so, just don't approve the port by NOT replying to the SMS you should receive.
If this was a landline transfer, contact them to cancel the porting request.
Public Mobile should then assign a temporary number. Then log into your self serve and go to the Change Number option under you MY PROFILE section to port the correct one over.
EDIT: if you did approve the port via text message, see if Customer Support agents can reverse it in the early stages of the process.
Customer Support contact here:
https://www.publicmobile.ca/en/bc/get-help/articles/contact-an-agent
02-06-2022 04:33 PM
I updated my initial reply with additional information you might wish to review, @Mdhatt1942
Hope this all works out. Please let us know if it did!!!
02-06-2022 04:31 PM
Ups! That can be painful if another number becomes your cell number...
ASAP contact agent so they might be able to cancel your porting request. But it might get very complicated as as soon as you port, other account is closed.
Send a private message to the CSA by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
You’ll need to be logged into your Community account for the link to work.
Be ready to provide account information to CSA to confirm your identity.
02-06-2022 04:31 PM
Thanks for the reply and how do I contact the customer support
02-06-2022 04:30 PM - edited 02-06-2022 04:32 PM
You'll need the Customer Support Agents for that one, @Mdhatt1942
Hopefully, you DID NOT respond "YES" to the port authorization request from your prior provider when transferring the number. You may also need to contact the other provider of the wrong number you initially ported over to let them know.
