07-23-2026 03:40 PM
I have just recently recieved my SIM card in the mail and am trying to do the activation process, I chose the option to transfer my number but the app is telling me its not a valid canadian number even though ive had this number my whole life, can anyone help? I would much rather keep my number than use a new one.
07-24-2026 08:14 AM
Thank you for the escalation! The customer is in contact with an agent.
07-23-2026 04:03 PM
okay thank you
07-23-2026 03:57 PM
@issacb 709-832-xxxx is a number from Grand Bank, NL. Telus has a "rate center" there and hence the number should be able to ported into Public Mobile. I would open a ticket with PM and see if they can help to submit a porting request for you or if they will advise you to get a new number first and process a porting request after.
To engage support, you will need to open ticket via private message here:
07-23-2026 03:47 PM
area code is 709 and next 3 digits is 832. Ive had this number always
07-23-2026 03:46 PM
@issacb is that a number from Koodo Prepaid? If so , the number can be ported. You just need to choose a new number first and then ask Public Mobile CS agent to port the number into PM got you manually
If the number is not from Koodo Prepaid, the please provide use the area code and the next 3 digits and we can confirm if the number can be ported into Public Mobile
