06-12-2023
05:28 PM
06-12-2023
06:35 PM
computergeek541
06-12-2023 05:48 PM
Two things need to happen for a successful porting.
- Your Rogers account must be active so don’t cancel your service.
- Reply to the text with YES confirming you are porting over to PM with the Rogers SIM in your phone. You have 90 minutes to reply or porting will be cancelled. If you missed this step, you need to contact a CS_Agent to restart the porting process for you.
Your Rogers SIM will continue to work until porting is completed…this could take about 1 hour.
06-12-2023 05:40 PM
@Fox1 There a number for live support to restart the port process for you will send it private message
06-12-2023 05:30 PM
I need public mobile to port my # from rogers
