06-12-2023 05:44 PM
So I guess I set up a 4 digit pin.
I don’t remember doing it. I only ever use one and that’s not it.
can I reset it somehow? Is there somewheee with my account info etc where I can make changes?
06-12-2023 05:56 PM
Yes this is something you create during the activation of your SIM but you can change it any time in your account under the Profile section.
06-12-2023 05:46 PM
@Kellyj you can reset the 4 digits account pin from My Account. just go to Profile page, click on the Pencil besides PIN and you can reset it
https://myaccount.publicmobile.ca/en/account/reset/pin
06-12-2023 05:45 PM - edited 06-12-2023 05:45 PM
@Kellyj Yes tap the pencil in your profile tab in my account and change it there
