06-12-2023
05:42 PM
06-12-2023
06:32 PM
computergeek541
I want to short my ring time.
I tried the codes with my voice-mail number and it didn't work.
Thank you
06-12-2023 06:39 PM
If you have volte then conditional call forwarding can apparently be fixed by support. If you don't then it no longer works.
06-12-2023 06:34 PM
@BKNS27 wrote:If you are referring to your voicemail box. I can’t remember on the voicemail prompt but members here will be able to help.
The number of rings needs to be adjusted by dialing the code provided earlier. I'm unsure of there being any menu optino for this.
06-12-2023 05:50 PM
06-12-2023 05:43 PM - edited 06-12-2023 05:55 PM
what kinda phone you using ?
adding..
https://forum.telus.com/t5/Mobility/Change-Number-of-Rings-Before-Voicemail-Picks-Up/ta-p/133522
