Over charged
Magoo4u
I live in Saskatchewan for the last 2 years I've been being charged tax for ontario. My address on file is for Saskatchewan but I'm still being charged for ontario taxes. How do I get this fixed ?
7 REPLIES 7
@Magoo4u   yes, as suggested in my post above, those are the only 2 choices 😞
Vouchers would be the only one if you want to keep the ON number
@Magoo4u  Yes that’s correct
Magoo4u
Ahh I see so if I wish to keep the ontario number I have and have had for like 13 years I will pay ontario tax unless I use payment vouchers
dust2dust
1. Change your number to a SK area code number.
2. Buy vouchers locally and pay your local tax.
The tax charge is based on the province that your area code is from.
hmm I wonder if real time payments would be local tax.
@Magoo4u   PM charges tax based on the location of your phone number's area code not the address on file.  You have been using an ON phone number and hence got charged that
You can either change your phone number to a SK number for SK tax.  Or you can buy vouchers from local stores.  You will then be charged SK tax at the store.  You can then load the vouchers using *611
@Magoo4u  Tax you pay is based on the area code of the number you have , so change it or in your case you could buy vouchers where you are pay tax there on it . And load them to you account and keep you old Same number
hairbag1
@Magoo4u
doesn't matter your on file address. You're taxed using the area code of your number.
