01-14-2024 01:25 AM - last edited on 01-14-2024 07:26 AM by computergeek541
Hi anyone,
I am trying to transfer my phone number from Phonebox to Public Mobile. But the old provider name"Phonebox" isn't in the list of the old service provider. I have had the account number from Phonebox. Can anyone tell me how to transfer the phone number to public mobile? Thank you! @CS_Agent
01-14-2024 12:34 PM - edited 01-14-2024 12:35 PM
Hi golfball,
Thanks for your reply. I have selected Rogers as a old provider. it works for my phone number transferring.
01-14-2024 11:59 AM - edited 01-14-2024 12:09 PM
That is what you would have to do.
Edit: PhoneBox operates on Rogers and Telus networks. You may be able to select the corresponding carrier and port that way.
01-14-2024 02:16 AM
Hi Softech, my phone number is eligible to move to publice mobile after checking in the link.. iDeos it mean that my phone number is portable into public mobile? And I have already had the account number from Phonebox. To get a temporary phone number, Does it mean to activate the sim card first for a new phone number? Thank you!
01-14-2024 01:41 AM - edited 01-14-2024 01:42 AM
yes, both Koodo and PM owned by Telus and use the Telus network, so, the result is the same
To port out from Phonebox, you need to call them and ask them for the account number
After you confirm the number is portable into PM, then please activate with a temporary number first
Once activation is done and confirmed working, you can open ticket with PM support and ask them to help to port the number from Phonebox and provide them PB's account number
To open ticket with PM support:
01-14-2024 01:38 AM
Hi Sansan,
The link is to check eligibility for koodo mobile. Is it the same as checking for public mobile?
01-14-2024 01:32 AM
Hi did you check eligibility?
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
