Porting issue with texts.
Chitch7275
I ported over from rogers a week ago. I can’t seem to send/receive texts, and can’t get an OTP for the app/to log into to eversafe bc the text isn’t coming through.
please advise
Frank52
This might be an issue related to your porting process from Rogers to Public Mobile. Have you tried contacting the porting team yet? That could help the issue. I believe a number was sent to you.
If that does not resolve the issue, please contact customer service using the following link:
Please be sure to explain the issue to them. They will respond to you in your community inbox so check it from time to time. (Little envelope icon on the top-right of this page).
You can contact the number I provided you to your mailbox in the top right corner of this page. Also, you can contact Rogers to confirm your account is closed in case you get charged from them. I also sent you a link to reach out to a CS Agent to reset things for you.
Chitch7275
Hi, I called immediately after I signed up with public and rogers confirmed the service would be canceled after 48 hours. I was using a rogers Esim.
Chalupa_Batman
Hey @Chitch7275
Have you confirmed there is no service on the Rogers SIM card? Place the Rogers SIM card in to make sure. If you do have service, I'll send you the porting team number to help fix the issue.
Chitch7275
I’m having the same issues. Been with the service a week, can’t send/receive texts, and can’t get a text OTP for eversafe to log into the app.
