Pronlem
01-14-2024 09:43 AM
Hello. I transfered my ligne to public mobile. Only the mobile data is working. I can not make or receive calls. My application is not working. Thank you for help.
My Account
01-14-2024 12:47 PM
This might be a porting issue. I can end you a phone number to contact a porting team to ensure everything went through correctly. Otherwise, they will try to assist you in resolving this issue.
The number will be sent to your community inbox so keep an eye on the little envelop icon for an incoming message. Unfortunately, we cannot post phone numbers in the main community page.
After contacting the porting team, if you still encounter issues, I would recommend submitting a ticket to the customer service team for further support. You can use the link below to submit a ticket.
Please be sure to explain the issue to them. They will respond to you in your community inbox so check it from time to time.
01-14-2024 10:15 AM
What about texts? incoming and outgoing? If not tried, maybe reboot your phone. Network reset of phone (this will erase wifi password settings)
Do you still have your old carrier SIM card? Try in your phone. Is it still active?
01-14-2024 09:51 AM
01-14-2024 09:46 AM - edited 01-14-2024 09:47 AM
@Bob77 Have you rebooted the phone ? Did you reply YES to the confirmation text to port with old providers sim in the phone ??
you can also submit ticket with support using this direct link
send a private message To CS_Agents
