08-21-2024
06:47 PM
08-21-2024
10:52 PM
computergeek541
Hi, the system doesn’t recognize my virgin mobile number, says it doesn’t exist. Is this just an error or does PM not transfer Virgin Mobile Canada numbers?
08-22-2024 04:15 PM
08-21-2024 08:45 PM
08-21-2024 06:51 PM - edited 08-21-2024 06:52 PM
I'd suggest you just take a new number just to get you started...then get Customer Support involved if you still are unable to port in successfully. BTW..your old account needs to still be active in order to port in to Public Mobile.
added link to Customer Support messaging..
08-21-2024 06:50 PM
Check this link to confirm your number can be ported.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
