08-27-2024
11:56 PM
08-28-2024
08:13 PM
Dunkman
Hello,
I just received my SIM card and wanted to transfer my phone number from Rogers but they say 'this number is not available for transfer'.
I have an account with my landlord, would it be the reason?
In that case, what would be the solution? A new number?
I tried to call Rogers but it's the virtual assistant and that doesn't help.
Thank you
08-28-2024 03:59 PM
Hello,
It's still active but I'm not the main client, I'm attached to them.
I created a ticket and PM helped my out. The transfer should be done by the end of the day.
Thanks
08-28-2024 08:44 AM
While most numbers can be ported into PM, some numbers cannot, please check if the number can be transferred into PM using this link:
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
08-28-2024 08:27 AM
Hi, your account at Rogers must be active to transfer your number. Not sure what you mean a account with your lanlord ? You can try to call Rogers.
