10-06-2023
12:31 PM
10-07-2023
10:17 AM
Dunkman
10-06-2023 12:59 PM
Currently - cannot be done. Only physical SIM is possible to move from phone to phone without issues.
10-06-2023 12:35 PM - edited 03-31-2024 08:41 PM
HI @Dumbo
For eSIM with new phone, you have to re-buy a new one for $5.
Yes, while eSIM is "cool", there are disadvantages as well. For eSIM, if you have a new phone, or if you ever wipe your phone, you will have to re-buy a new eSIM again. There is no such problem with Physical sim card.
To rebuy new eSIM, first, download the app on your new phone. Click Account from the bottom, then click Purchase SIM Card and select eSIM. Once it confirms your phone is eSIM compatible, click Pay $ and Install and following the prompt to complete and purchase and install eSIM on your device
10-06-2023 12:33 PM
hi @Dumbo
you have to buy new eSIM, you cannot tranfser for free
