06-05-2023 11:54 AM
Hello @CS_Agent - I waited 90 minutes and did not receive a message from previous providers. I believe I need to re-request transfer. How do I do that? Thank you.
06-05-2023 01:12 PM - edited 06-05-2023 01:13 PM
You need 2 requirements for the text to come through:
- Your previous account must be active.
- Leave the old SIM in your phone.
As others have noted, you need to contact a CS_Agent to restart the porting process for you but leave the old SIM min your phone.
Your old SIM will continue to work until the porting process is completed then power off your phone and swap the SIM and power back on.
06-05-2023 12:00 PM
your account with previous provider is still Active...right ??
06-05-2023 11:55 AM
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
06-05-2023 11:54 AM
@Gal424 Will send you number for live support to restart port process for you . Private message
