07-12-2026
04:28 PM
- last edited
3 weeks ago
Dunkman
i just subscribed and forgot to add my friend’s reference number..how can I do that now
07-12-2026 06:05 PM
07-12-2026 04:28 PM
You can ask PM to add it back for you
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
