Lost sim card. 2 factor verification issue
Tío2026
I lost my sim card. Ordered a new one. Trying to set it up, I'm getting the 2 factor verification which keeps sending the code to my number. Since I lost my previous sim card, I dont have access to my texts. It is not giving me the option to send the code to my email.
Agent won't call you, but they will message you via private message in the Community inbox
Follow this
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
Tío2026
Thank you for your reply. I tried everything and nothing works. I cant get over the 2 factor authentication step since its not letting me pick the email option. Im not sure how an agent will call me when my number is not working
Chalupa_Batman
Hello @Tío2026
Try clicking on "Didn't Get The Code" and see if there is an email or voicemail option. If those two options aren't there, reach out to a CS Agent to help you get back in. And once you're back in, here is where you change your code.
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
