11-23-2022
09:43 PM
11-24-2022
02:20 AM
computergeek541
Been waiting since Saturday to get my number ported so I can use my phone and still haven't heard anything I really need my phone as I am always outside in the woods
11-24-2022 01:50 AM
if you literally mean the woods. I don't think you're at the right company... I wouldn't switch
11-23-2022 09:47 PM - edited 11-23-2022 09:52 PM
@Bubbie are you porting from mobile or landline/VoIP?
porting from landline/VoIP could take as many as 7 business days
But if porting from mobile, it should be done within 2 hours AFTER YOU REPLY YES to the text from your old provider
The next question is, can you at least able to make outgoing calls? how about data? I am wondering if it is a sim care provisioning problem or porting porting
To confirm if porting is done, there is a number to call to talk to live support. i will message you the number. Please check your Community inbox
11-23-2022 09:46 PM
Where are you porting from? Did you leave old sim in to get confirmation to allow the port? Have you rebooted your unlocked phone? Check your email icon top right. I will send a number for you to call.
11-23-2022 09:46 PM
@Bubbie Please contact PM CS_Agent asap with details. Porting in a number shouldn't take that long.
Here’s when and how to contact our Customer Support Agents:
