Unauthorized message when logging in
Tenderinfj
When I try to log in as usual, it comes with a message saying unauthorized. Any tips to resolve this? How do I speak with a customer service agent about this? Thanks!!
I've seen this error message before, and while clearing cache and cookies (or incognito mode) might help in some cases, I've beem able to log in immediately after by simply trying to log in again without taking any special steps.   I've also recommended the earlier mentions steps to others and it's a good thing to try, but it doesn't always fix the website errors.
will13am
I get these strange errors from time to time also.  Retrying has always worked for me.  I suspect that if I was consistently using incognito mode, these problems might not occur.
@Tenderinfj
I had the same problem yesterday when trying to login on my phone.
No problem today when login on my phone. I don’t know if the site was down or a glitch.
Try again on your PC and see if that works.
NDesai
@Tenderinfj Try using incognito/private browsing mode and see if it loads properly. It supposed to ask you for the 2FA authentication through SMS or Email. If you forgot your password, you can reset it here: https://myaccount.publicmobile.ca/en/forgot-password
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
JK8
@Tenderinfj
 Clear your browser cache and then open a new window in incognito. Use the Forgot your password link if you need to.
