09-29-2023
07:11 AM
09-29-2023
10:08 AM
Dunkman
Hi, I used all my minutes as the month just began for my pre-paid. Can I purchase another top-up card to reclaim my minutes back.
09-29-2023 07:44 AM
if.i5 is just couple days before renewal date, it might be more advantageous to have PM support help to make an early renewal.
Of course if you always run out of minutes, consider upgrade tonyue $25 plan with unlimited outgoing minutes
if you want to save money, since incoming is still free, you can use VoIp app TextNow to make outgoing calls using Wofo
09-29-2023 07:43 AM
You might be thinking of a pay as you go idea where you draw down balance when you use features. This place is not that. This is a 30 day plan (or 90 but that's not your plan).
The add-on mentioned is great for that plan. And calling add-ons stay on your account until used. But if you're going through minutes that fast then you might want to look at the $25 plan.
09-29-2023 07:14 AM - edited 09-29-2023 07:16 AM
@DorisRotter You just need buy 500 Canada wide minutes booster add on for $5! From subscription add on page
