08-06-2020 03:11 PM - edited 01-05-2022 12:25 PM
Hi
I heard from PM group that they are launching $30 - 2GB plan - is 500 GB auto pay still apply ?
12-08-2020 09:46 PM
Thank you
08-06-2020 03:28 PM
@mpcontact Thanks for the solution 😊 but are you sure you have marked the correct response as I was just pointing out a typo made by @popping in his post? I think perhaps @gblackma already answered your original question.
08-06-2020 03:24 PM
@dabr wrote:
@popping wrote:
@mpcontact wrote:Hi
We don't until that plan details is known tomorrow.@gblackma is correct. The $30 plan is 1.5GB + 500MB bonus data with autopay enable. You will also get the $2 off with autopay enabled. $13 for 2GB plan.
@popping Just a small correction, I think you meant to say $28 with autopay?
Sorry. Fixed my post.
@mpcontact wrote:$13 for 2 GB ?? - I did not get it ?
My bad. It should be $28.
08-06-2020 03:22 PM
@mpcontact Yes, that's just a typo 😊
08-06-2020 03:21 PM
@popping wrote:
@mpcontact wrote:Hi
08-06-2020 03:21 PM
08-06-2020 03:14 PM - edited 08-06-2020 03:22 PM
@mpcontact wrote:Hi
@gblackma is correct. The $30 plan is 1.5GB + 500MB bonus data with autopay enable. You will also get the $2 off with autopay enabled. $28 for 2GB plan.
PM is basically offering the same Quebec $30 2GB plan to all provinces.
08-06-2020 03:13 PM - edited 08-06-2020 03:15 PM
No @mpcontact it's 1.5 gigs and 2 gigs total with the 500 mb autopay bonus. Stay safe.
