12-30-2023 10:17 AM - last edited on 12-30-2023 08:27 PM by computergeek541
Hi, trying to solve a time sensitive deal offer and submitted two separate tickets for resolution, no CS contact in any way, took screen shots of ticket info, so being time sensitive, this is not a great situation to be in, to hope someone maybe notices. Any thoughts to expedite process.
12-30-2023 08:27 PM
@Winger1919 wrote:Yes, seems like best solution. Thank you.
self solution removed
12-30-2023 10:50 AM
It won't @Winger1919 , so long as there is an active communication in the works regarding an issue you feel you may succeed at.
Their failure to reply doesn't give them the ability to say "you're too late". Surely if the front line customer support agents say this, a request to deal with a more experienced CSA will see it through.
Just stay calm and polite and you will get better outcomes with them.
12-30-2023 10:50 AM
12-30-2023 10:36 AM
@Winger1919 So this is for the 50GB for $39 offer ? It’s still in our accounts and you can make plan change for still . Just make change for next renewal and not immediately or you lose money on your current cycle
12-30-2023 10:31 AM
Yes, I see that area now, and have been patiently awaiting a communication and ideally a resolution to our issue, so I will check there going forward.... just get the feeling like time will pass and resolution regarding an offer will expire.
12-30-2023 10:26 AM
@Winger1919 wrote:Via messaging, and I do not see any envelope symbol, but I do see an alarm bell symbol
click on the avatar on the top right to expand the menu and you will see the inbox icon
or use this direct link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
12-30-2023 10:25 AM - edited 12-30-2023 10:26 AM
@Winger1919 If you don't see an envelope icon click or tap on your avatar to the right of the bell and there is a drop down menu with Messages. Not all devices show the envelope, took me a while to figure that one out myself!
12-30-2023 10:24 AM
12-30-2023 10:20 AM
@Winger1919 Just keep an eye on your community in box for agents reply . Or you can use this link to the community in box
12-30-2023 10:20 AM
No way to expedite once a ticket is sent.
Just keep an eye on your private message inbox for reply @Winger1919
12-30-2023 10:20 AM
did you open ticket via chatbot or messaging?
usually they reply resonably quickly. Check your Community inbox. If no reply in 2 hours, please message them again:
Also, mind to share the issue? not sure if we can help or suggest workarounds
