07-14-2023 11:56 AM
Why do all the plan details end with? This plan is for Quebec residents only and intended for use in Quebec.
07-14-2023 12:23 PM
@Grinch- When you change your region on the plans page you'll get possibly different plans available for that region. Particularly for Quebec. But I see now that the roaming plan is available for all.
As for the Quebec only plan, we so far know that texting works to anywhere from Quebec. We don't yet know what happens with calling. And then we don't know what happens with both outside of Quebec.
07-14-2023 12:17 PM - edited 07-14-2023 12:17 PM
@cardstoweb wrote:I'm looking under Ontario and every plan at the end of Offer Details says this.
HI @cardstoweb
that's "one template fits all" approach 🤣 (efficient or lazy 🙂 )
just ignore it. you are not activating Quebec plan
07-14-2023 12:16 PM
No I am definitely under Ontario and all plans say this under Offer Details
07-14-2023 12:16 PM
This is how references work. In the Quebec plans, the Quebec only plan will have a superscript indicating a reference in the details. That symbol is at the plan area and on this details references. You can ignore it in this case.
As an aside, I see a Canada-US plan now in ON.
07-14-2023 12:14 PM
HI @cardstoweb
if you are in Ontario, you can safely ignore that line about Quebec plans
07-14-2023 12:13 PM
07-14-2023 12:12 PM
no worry, that terms is for Quebec plans only., the terms do not apply to those plans designed for Ontario
07-14-2023 12:12 PM - edited 07-14-2023 12:14 PM
@dust2dust It appears that OP is referring to Quebec plans for USA Canada.
But some Quebecors are going to move to other provinces or states… then what?
Would the Canada USA plans be good for Americans living in the USA?
07-14-2023 12:11 PM
but i'm looking under Ontario plans and its under Offer Details
07-14-2023 12:01 PM
Are you reading the fine print page? That last line is referenced in the QC plans for the one plan that seems to be Quebec only. If so, then good for you for reading the fine print.
07-14-2023 12:00 PM
@cardstoweb wrote:Why do all the plan details end with? This plan is for Quebec residents only and intended for use in Quebec.
HI @cardstoweb
I don't see the line. Maybe you picked the wrong location on the page? which province you are in?
try this:
07-14-2023 11:59 AM
are you in Quebec and checking the Quebec plans? Yes, some plans are designed for Quebec residents only and need a credit card linked with a Quebec address to prove residency and activate
