09-30-2022
08:02 PM
09-30-2022
08:54 PM
computergeek541
I tried to log into my account and my password didn't work. I tried to reset the password and the email with the digits to reset my password never arrived. Also, I ordered a sim card 15 days ago and it never arrived. This service is lousy. So I ask for my money back and I will activate a plan with another provider.
09-30-2022 10:18 PM
09-30-2022 10:10 PM
Another useless cut and paste post from Remember 🤪
09-30-2022 08:54 PM
The SIM will take up to 3 weeks to arrive depending on where you live.
What was wrong with the first SIM?
09-30-2022 08:18 PM
You could pay by voucher. You can enter it in through 611. You can use real time payments in some stores. But I assume you don't have a working sim so there's not much else you can do.
09-30-2022 08:09 PM - edited 09-30-2022 10:08 PM
Nice post 🤪
Most of us had no problem getting started with Public Mobile. The service doesn’t seem to suck for the rest of us… maybe it’s just you. You don’t have a SIM card yet so why would you want your money back?
09-30-2022 08:08 PM
check the update browser, open incognito mode,clear cache,cookie. try again
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot. ask them to check your order
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
