12-12-2024
10:12 AM
12-12-2024
11:03 AM
computergeek541
My CURRENT SUBSCRIPTION include
Unlimited Canada-wide Talk;
Unlimited International Text;
but when i try to make a phone call to another number ,telling me I used all my talking minutes? that's insane and can't raise tickets . the service sucks !
I hope the problem can be solved ASAP!!!
12-12-2024 10:41 AM
hi @dalinqin
so all good? you just call the wrong wife (the wrong number)?
12-12-2024 10:37 AM
thank you all for the quick help , that's my bad ,I made a stupid mistake . the old post in 2022 mislead me thought I was facing their issue. actually I have 2 number under my wifes contact info , totally my bad ,sorry !
12-12-2024 10:35 AM
hi @dalinqin
try calling other numbers as well.
and maybe the problem is on your wife's side. Ask her to reboot phone and check if anyone else can call her
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
12-12-2024 10:34 AM
btw ,i didnt change anything including subscription ,plan ,paymant anything .
just now I tried to call another person ,the call even worked ,just when call my wife's number it's not working (she is using public mobile either).
12-12-2024 10:33 AM
hi @dalinqin
did you try to call with a 1 in front of the 10 digits? try also with just 10 digits without the 1 as well
12-12-2024 10:31 AM
thank you very much for the info ,but I actually searched the old posts and already reboot my cell several times .didnt give it solved . I have used public mobile for nearly 10 years ,never happened before .
12-12-2024 10:20 AM
@dalinqin Try rebooting the phone or reset network settings and test again . Be sure to put a 1 in-front of the 10 digit contact aswell , also check
Outage map in your area:
https://istheservicedowncanada.com/
if not outage and account is active not suspended and reboot / reset network settings didn’t help
submit ticket with support to refresh your account
12-12-2024 10:18 AM
hi @dalinqin
it is a common glitch. Usually, you just need to reboot the phone, Reset network settings and it will work again
try also to make calls with a 1 in front of the 10 digits.
