10-20-2022 04:41 PM
Hi,
I was recently going to the country where Public Mobile does not offer roaming, my phone was with me as I was using it solely on wifi. After I came back I wanted to check out new 4G plan, logged onto self serve portal and noticed there are outgoing calls made almost every day to the same local number which I don't recognize while I was abroad. How is that possible?
Thank you
10-20-2022 04:45 PM
Thanks @dust2dust and @softech. That's the case - number ends with 4001.
10-20-2022 04:44 PM
@winamp what is the number?
Please note calls to voicemail from yourself or your friends (due to forwarding) will be shown there as well
10-20-2022 04:43 PM
It's likely that people called you and then the system forwards them to the voicemail system. If the number ends in something like 4001 then that's what it is.
