03-31-2025
01:14 AM
03-31-2025
01:50 AM
computergeek541
Can we check in app call history like missed calls incoming or outgoing calls.
03-31-2025 01:18 AM
@Kasif yes , go to Usage History page on the app Ang it had the info
For Voicemail, if you see incoming or outgoing calls going to a number ends with 4001, it is that some calls got routed to voicemail
