4 weeks ago
Hello all! I am a new customer, i just recently joined on Friday. I have not received a text message since my service supposedly was connected (telephone calls are working just fine)… I never received the confirmation to my secondary phone number either. Someone please help? Does this company have no help desk?
4 weeks ago - last edited 4 weeks ago
I presume texting worked previously on your device with another carrier? (if you had service elsewhere before coming here ...)
If you are using a physical SIM card (and not an e-SIM), try the Public Mobile SIM card in another device to see if all services work with that other device.
Otherwise, you may need to contact customer support to have them look into the issue. Especially wherein you advise that calling (in and out) , and presumably data works.
4 weeks ago
I mean both. I received the email confirmation but I had been asked to give a secondary phone number for a 6digit code that I never received. I have not received text messages from any of my contacts, and my contacts are not receiving text messages that I send to them.
4 weeks ago
That is correct!
4 weeks ago
To also confirm, @Jackie63 , you do mean SMS messages and not iMessage or some other RCS service, correct?
4 weeks ago
@Jackie63 Do you mean you can't receive text messages from anybody at all, or just a confirmation text from Public Mobile?
hopefully customer service options is something you investigated before joining up here
4 weeks ago
@Jackie63 - If everything seems to work normally (SIM card from old provider does not work) you are good to go. I never received a welcome text but my service started working.
If you want to contact Public Mobile, you can here:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article! ⚠️
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
