Texting not working
04-23-2024 05:46 PM
Transfer from fido 2+ weeks ago
Android galaxy s20
Verification code not working or texting
Lte and calling working
Service
04-23-2024 05:50 PM
@Zee3 - Please do this to fix SMS issue:
- If you are on a physical SIM, please try popping it out of your SIM tray and insert it into another device to re-provision.
- If you are on eSIM, please contact CS_Agent for re-provisioning your eSIM:
If the physical SIM tip doesn't work, please contact CS_Agent for re-provisioning your SIM:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
04-23-2024 05:49 PM
hi @Zee3 common issue for new activation but support agent can help. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
04-23-2024 05:49 PM
PM has problem provisioning text capability for new activations. ( And if you are an iPhone user, iMessage activation is impacted without a working SMS. )
PM is working on a fix but for now, they can only resolve the issue on a case by case basis. Please open ticket with PM support:
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
