$29 10GB Plan now upgraded to 20GB!
04-23-2024 05:54 PM - edited 04-25-2024 08:35 PM
As noted above, Public Mobile has changed one of their plans to an improved plan - a $29 20GB instead of 10GB of data. It is still 4G LTE speeds of up to 100mbps. And if you are wondering if it is for new activations only, it isn't!
https://subscribe.publicmobile.ca/en/ab/activation/plans/20GB-4Gspeed5
Also in the plans page it doesn't say it is a "Promotion" plan but when you click on the plan it says that it is a "Promotion" plan.
Plans
04-23-2024 06:16 PM
@colleeno - Everything Public Mobile says is "Limited Time" as in "Scramble or else you won't get it." A usual tactic to make people worry when it will come back soon enough.
04-23-2024 06:11 PM - edited 04-23-2024 06:11 PM
It is noted as a limited-time plan on PM’s website’s landing page.
04-23-2024 06:07 PM
@Chalupa_Batman - Yes, it is honestly funny to see for $3 more there is a 16GB data boost. But before today it was $29 10GB. 🤣 But yes... now it is hilarious to see that. 🤣 PM is just trying to retain customers with their lousy 15 points offer and a spec bump on a plan.
04-23-2024 05:57 PM
You have to laugh...
