Text only going out to other iPhone users
Michelle28
It seems that sone of my texts r going out no problem but people with android phones texts r not delivering. Anyone else have this problem or ideas on how to fix?
Dunkman
@Michelle28
Also, you can check your iMessage settings.  You are able to sent texts via your cell number and email address (apple ID).  Click on both options
Chalupa_Batman
Hey @Michelle28
I had that problem too this week. I went into my network settings on my iPhone and reset them and then rebooted. Problem was solved and back to normal.
hi @Michelle28 did you check you iMessage settings to see if the Send as Text and MMS message options are enabled?
