10-20-2023 08:29 PM
After i ported my number i still cannot receive any text messages andci don't understand why, this has literally never happened before, do u need to change my number please help,
10-20-2023 09:32 PM
Like I mentioned before, scroll up to the top right corner and you will see the mail box with the number you need to call. It might be too late in the evening but try tomorrow morning.
10-20-2023 08:41 PM
When i did have the old sim yez it would take and receive calls and text on my whatever phone had rhe sim, i contacted shaw to they said it was public mobile responsibly
10-20-2023 08:38 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls, wok then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
10-20-2023 08:37 PM
I'll send you the porting team number and they can fix it for you. Look up at your mail box.
10-20-2023 08:36 PM
I noticed ot on verification text i dont receive should i just change my number
10-20-2023 08:34 PM
That shouldn’t happen @Sachin666
try rebooting, resetting network connections and removing and reinserting SIM card
10-20-2023 08:34 PM
I texted yes the old sim cardchad been destroyed
10-20-2023 08:32 PM
Hi @Sachin666
When you ported over, did you get a text message from your other provider asking permission to port number? Did you reply yes? Also, if you put your old providers SIM card in, do you see their name up top and can you still make calls?
