10-20-2023 08:28 PM
Hi CS_Agents, please help. I have been locked out of my account all day. Waited 3 hours and the system keeps rejecting my information. I had to create a new account to post this.
10-20-2023 09:35 PM
Once a CS Agent helps... download via WiFi if you want.
If you click on the Sent, it will show you sent it. Don't worry... it might be a bit before they get to you or may get to you in the morning. I always find later in the evening a very slow response as they have little to no staff on this late. Then again, it might be in the morning.
10-20-2023 08:40 PM
Never downloaded it before and it's impossible to login now since of course I'm logged out. I will try once I get a response from CS_Agent.
Do you know if there is a way to see the status of the ticket? I sent a PM using the link, but I can't even find the conversation on my profile to confirm the message was received.
10-20-2023 08:38 PM
Just for the record @Joe15 I use the app for everything. It's never failed me so far.
10-20-2023 08:37 PM
I tried all of that to no avail. The locking out system is too faulty. Particularly for a self-serve service like Public Mobile.
10-20-2023 08:36 PM
Try clearing cache and cookies and using an incognito/private tab to login
if available, use laptop or desktop to login
10-20-2023 08:31 PM
Just did, thank you.
10-20-2023 08:30 PM
HI @Joe15
To reach an agent click on this link.
Keep an eye on the top right corner for their reply.
