04-19-2024 11:15 AM
Hi I can’t send text it says there no number when I try to add phone number it won’t save
04-20-2024 08:50 PM
I did send message and heard nothing back and that was 3 days ago
04-19-2024 07:23 PM - edited 04-19-2024 07:29 PM
04-19-2024 07:23 PM
Hello @Plss
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
04-19-2024 07:16 PM
Hi I deleted my SIM card and I bought another eSIM and I was told to send a copy of the payment where do I send it
04-19-2024 04:12 PM
thanks
04-19-2024 03:22 PM
I called Telus porting and they had to do a refresh on there end now everything is working great
04-19-2024 01:35 PM
@Plss You will need to try again with support because they're the only ones who can fix this.
04-19-2024 01:20 PM
So I send the text and they don’t get it and I called to see if they transfer my number and there is no record
04-19-2024 12:51 PM
Ok thanks I did send a message
04-19-2024 12:49 PM
There seems to be a glitch in the system lately with new subscribers. You will need to click on the Chat icon and type in Submit a Ticket for an agent to help reset your SIM.
04-19-2024 12:45 PM
Hi I join pm on April 15 and I just transfer phone#from other provider yesterday I can call out in get calls use data but when I try to send a message it says I need to add phone number so I go to I message and try to add phone number and when I click save it don’t save any suggestions what I can do
04-19-2024 12:08 PM
I just checked it was April 15
04-19-2024 12:06 PM
I did and say need to add phone in I message
04-19-2024 12:05 PM
I can call and use data
04-19-2024 12:04 PM
Or the 17
04-19-2024 12:04 PM
04-19-2024 11:24 AM - edited 04-19-2024 11:25 AM
When did you become PM customer?
How about other services? Calls, data?
Try adding number to your contact list first and then text to that number.
