06-07-2026 04:25 PM
I have a new Telus SIM card wonder if it will work with PM plans.
06-07-2026 04:48 PM - last edited 2 weeks ago
06-07-2026 04:33 PM - edited 06-07-2026 04:35 PM
@Anerkons wrote:I have a new Telus SIM card wonder if it will work with PM plans.
No, a Telus SIM card will not work with Public Mobile.
Even though Telus completely owns and operates Public Mobile on the exact same network towers, their SIM cards are not interchangeable. Each brand uses its own distinct SIM card programming to authenticate with the network.
To use Public Mobile, you have two options.
An eSIM. If your phone supports it, you can buy and install a digital eSIM instantly right through the Public Mobile app during activation.
A Public Mobile Physical SIM: You can buy an official Public Mobile physical SIM card online (via Amazon or Public Mobile's website) or pick one up in person at a Mobile Klinik store/kiosk. It's been also mentioned here you may try this link to find a local Telus store. https://www.publicmobile.ca/en/bc/pick-up-SIM
06-07-2026
04:28 PM
- last edited
2 weeks ago
