11-04-2018 09:13 AM - edited 01-05-2022 02:24 AM
Hi everyone,
I'm trying to help my niece port her number from parent company Telus to her already activated Public Mobile SIM. However, when either she or myself enter her number to check for portability, we get this:
We were unable to transfer the phone number you entered. Try one of the following options:
- Make sure you entered your number correctly.
- Select a new number.
- Contact the Public Mobile Community for further assistance.
Would anyone have any ideas before I resort to DMing a mod?
Thanks
11-04-2018 12:15 PM
Sometimes Telus will not release the phone number. I bet if she takes a new number it will work. Good luck.
11-04-2018 09:51 AM
MDN = mobile directory number 😉
Just a quicker way of saying cell phone number, haha...
Although I guess "TN" is less specific, more intuitive, and even one less keystoke - maybe I'll use that in the future 🙂
11-04-2018 09:51 AM
@liphom_1086 just anothe fyi the mods are a little overeloaded at the momentand have been replying in 72+ hours. so dont be worried if you do not her a reply. anything after 4 days then i would post again.
11-04-2018 09:46 AM
also there are some rare occasions where numbers can not be ported. this only happens to some specific exchanges. I have only seen it mentioned once in the forums. hopefully this is not the case in your situation.
11-04-2018 09:46 AM
Thank you both for your prompt replies! I really appreciate the help.
Cheers
11-04-2018 09:46 AM
Sorry about that.... I was wondering about the MDN term myself.... I am not the the telco field....
Saying that
private message: Moderator_Team
Send a private message to moderator through the following link :
Please include in the private message your phone number, your account number and PIN code.
11-04-2018 09:44 AM
@liphom_1086 just message moderator team account.
full instructions below:
How can you get help with your account, activation, or service?
In your message please include:
If you have a Porting issue, please also include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
11-04-2018 09:40 AM
I was hoping my use of terms like MDN, pre-validate, and "parent company Telus" would indicate that I work in CS for a telco myself and I'm aware that Public is a brand of Telus... lol. I appreciate your help nonetheless.
My first inclinstation was to DM a mod but I figured I'd see if anyone had any further ideas here first.
I guess my next question would be... is there a logical way to choose which mod to DM or should I just pick the first random one I find?
11-04-2018 09:36 AM
Telus and Public Mobile are the "same" company so usually porting is easy and quick. Is the phone number a corporate account? If so, you will need help....
If you already tried twice as described above, you will likely need to contact moderator then. Include your neice's Telus phone number, account number and account holder name....
Maybe other community members have other suggestions.......
11-04-2018 09:28 AM
Thanks for your reply!
This has been tried on 2 different accounts on completely different computers and browsers.
The Telus account is postpaid, and it is currently active.
She first attempted this weeks ago and got the same error, and I tried it yesterday as well.
11-04-2018 09:23 AM
Is your neice's telus account prepaid? If so, might need to get moderator help.
Need to make certain that the account is active presently.
PM was doing a maintenance on their website overnight to 10 AM EST, so not sure whether that is affecting the porting process at the present time. I can access my account now though, but might want to try again in another one hour....
Also, can try a different webbrowser, clearing cache or incognito/privacy mode somtimes helps since the website is finicky....
