Telemarketers
vincep
I keep getting shackecoin telemarketers calling me 20 times a day for the last two weeks ..calling from different numbers from different provinces...its harrasment and I need to block all calls from IP address ...please help
JL9
Unfortunately this won't be going anywhere sign, frustrating for sure and you can block numbers and change settings but it will always be a game of whac-a-mole and some will slip through - don't worry they will burn in hell 🙂
barrascuk
@vincep
Have a good contacts list.
Set up your Do Not Call settings to only accept calls from your contacts list 24/7.
Set up your voicemail to ask caller to include their name and number in the message.
Update your contacts list accordingly.
Those annoying callers may or may not leave a voicemail.
@vincep  - we are all customers and members like you here on the forum. Public mobile representatives can be contacted by the ticketing system (SIMon Chatbot) in the Get Help section.
But, from a public mobile level don't think they can do anything about robocalls. Very annoying sounding though.
Hopefully whoever is doing this drops your number soon.
You could change your number if you really wanted to; but, anyone could be affected by these, but we just hope we don't.
edit grammar
HI @vincep   you meant phone number and not IP address?
It's incoming calls, if they are using different numbers, it's hard to block one at a time
If you just joined and just got a new number, you can try Change number and get a new one
If it is an old number that has been with you for years, you likely do not want to give up.  You can use your device feature, there are new feature that only ring for people on your contacts.  You can use that
