Talk mins
Friday22
Looking to buy to buy add-on plans for Canada wide talk, but can only find Canada wide long distance talk. Is this the same? Just need to make local calls, not long distance…thanks
hairbag1
@Friday22....do you have access to wifi ? If so, consider downloading the free voip app TextNow. You can call most any US or Cdn number for free using your wifi. Free texting as well.
Yummy
Every current PM Plan offers Canada wide minutes.
$15 Plan is limited to 100 outgoing minutes and you can always buy add-on 500 min for $5 (1min = 1 cent) Canada Wide Long distance which works for local and long distance calls.
Please note: Purchasing add-ons is two step process: 1. add funds to your account and then 2. actually purchase correct add-on.
BeachNBeer
@Friday22 You first have to have an actual plan that you pay for every 30 days. Such as the $15 plan.
Then you can buy add-ons through your account to add more minutes.
You can buy the $5 add-on for 500 Canada wide long distance minutes. This add-on is for local calling also.
Friday22
Yes… 🙂
@Friday22
Yes,  it is the one  you want  🙂
dust2dust
Yes Canada-wide means anywhere in Canada. Are you on the $15 plan and out of outgoing minutes?
