phone compatibility
DerekThomas
It appears the check your phones compatibility is not functioning. Would this phone be compatible with the network. The "Cat S52"
Interesting that both post with numbers did not end up in Unmoderated items.
@DerekThomas
Yes, the Cat S52 will work with PM on B2 (1900), B5 (850) on 3G and
on all 4G frequencies (1,2,3,4,5,7,8,20,28,38).
@DerekThomas
Your phone would work on PM.
this is the spec to your phone and the BOLD are the compatible bands with PM
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 20, 28, 38
Yummy
Nah, that feature is most likely difficult to update all the time so it is not working.
As long as it supports PM frequencies, it should work. Look at Help for assistance as if I post it here the whole post might be removed by PM AI... 😞
