10-27-2023 12:18 PM - last edited on 10-27-2023 10:54 PM by computergeek541
I moved two phone lines to Public Mobile, and the transfer process was straightforward. However, there is a peculiar issue: both iPhones can send iMessages to numbers not on Public Mobile, but when sending iMessages between the two lines we have on Public Mobile, it doesn't seem to work. Any thoughts on why this might be happening?
10-28-2023 12:03 AM
we have resolved this issue...there was a glitch in the IMessage settings the phone number on the one phone was checked off, then for some reason, it was not, a simple reset of the phone and tried again, and we got it, and all messages are blue now....thanks for all the help
10-27-2023 06:10 PM
iMessage is using data and PM has no control over it. So, as long as you have internet, that should work. I'd check this:
1. Does internet work (turn off wifi, open browser and search)?
2. Did port finish successfully? Call each other from that line and check what is the number. Also check in settings (General - Phone - My Number)
3. Are your settings ok (iMessage.. Lines to use. Start new conversation from?)
4. Are you sending to an email or to a phone number? If your settings are ok, I'd start new conversation and try
10-27-2023 02:02 PM
@NEILTONGS Have you tried turning iMessage off in Messages settings, waiting a short while and then back on again with both phones?
10-27-2023 01:36 PM
both are clearly seperate accounts, one in my name and one in my sons name , no connection
10-27-2023 01:35 PM
yes the infomation is correct
10-27-2023 01:34 PM
when the celluar is off on wifi only it still sends as a regular text in green , no imessages either way between our PM accounts
10-27-2023 01:29 PM
Yes, set up each line with separate emails, entered yes for both, with sim in each phone, signed up with the esim.
The physical sim is still in each phone, should I take that out? However it shows that it is not working anymore? (sounds like a silly question, but just thought abou that)
10-27-2023 12:58 PM
When you ported the 2 lines, did you reply to the text with YES with the old SIM in each phone? You have 90 minutes to reply or porting will be cancelled or in limbo.
Also, did you use 2 different emails for the 2 lines? Only 1 account or line/1 email address.
10-27-2023 12:58 PM
what happens when you turn off the cellular connection and send iMessages on Wi-Fi only to each other?
can you still not send and receive iMessages this way?
10-27-2023 12:38 PM
And the other phone?
10-27-2023 12:37 PM
Yes , the to and from are my phone number and my icloud email account , all correct
10-27-2023 12:32 PM
@NEILTONGS If you go into the settings for the Messages app do the send & receive numbers/emails look correct?
10-27-2023 12:30 PM
Both were transferred last night, both accounts were activated on Public Mobile, and my old accounts are now closed with provider.
10-27-2023 12:28 PM
How certain are you that two distinct accounts were made? The app may have caching issues when going from one account to another. Just exploring that idea. Maybe something got cross-linked.
10-27-2023 12:28 PM
We will receive one another's texts on our iPhones that are on Public Mobile, they show up green, when i text someone else's iPhone, those are on Rogers, Chatr, and Bell, they are received and sent in Blue, however Facetime works for us on our phone on Public Mobile.
10-27-2023 12:24 PM
Does NATIVE (not apples imess) texting works between your phones?
