Switching plans now, will I lose my loyalty rewards?
anikal
I know we are moving to points in May, but if I switch my plan now, do I lose my loyalty rewards right away?
Thanks
@anikal
If you switch now, you will pay for your current plan plus your new plan.
If you switch on your next renewal date. Depending on your renewal date, you will probably receive 1 more Legacy Reward then it will switch to Points Rewards after that.
anikal
I still have my loyalty rewards as of now, I would like to know if I switch plan now, do I lose the rewards now, or do I lose it when everyone goes to points in May?
HI @anikal
it looks like they removed the loyalty rewards already.  But if you don't treasure the extra data they give you before the end of this month, then why not just switch now and see. Nothing to loss as you are not using the extra 150 days only bonus data
