01-15-2024 07:07 PM - last edited on 01-15-2024 08:41 PM by computergeek541
Hello, I already have a previous sim card that I was using with public, but it's not working anymore as I currently switched to a different carrier "Koodoo", but would like to switch back to public.
01-15-2024 07:15 PM
Thank you all for the help
01-15-2024 07:14 PM
@Jam04 Is your Koodo account prepaid or postpaid? If it's prepaid you will need to pick a new number and then have Public Mobile customer support bring over your Koodo number.
01-15-2024 07:13 PM
@Jam04 as other have already mentioned you will need a new SIM card and Amazon has the for $4.99 last I checked . And remember it’s best to use a different email then from before when you were with PM
01-15-2024 07:12 PM
@Jam04 - yes, you can get your old number ported (transferred) over to PM.
01-15-2024 07:12 PM
> Will I be able to keep the same number I'm not trying to have a new number. Also will a eSim work.
@Jam04 yes, eSIM will work.
And yes, if you are from Koodo, you number will for sure works here. Just choose to bring your number from the phone number selection step
01-15-2024 07:12 PM - edited 01-15-2024 07:13 PM
you'll be given opportunity to port in your number from Kodo when you activate the new PM account.
adding...
https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
01-15-2024 07:10 PM
@Jam04 sim cards can only be activated once and carrier specific. Please buy a new Public Mobile sim card from local Trlus/Koodo/Mobile Klinik or online at Amazon. Of course, you can also use eSIM if your phone supports
01-15-2024 07:10 PM
01-15-2024 07:08 PM - edited 01-15-2024 07:08 PM
