06-10-2024
09:03 PM
06-10-2024
10:51 PM
computergeek541
Hello. I want to switch plans (downgrade) for a few months (Plan $15) until I use up all my free data of 240+GB. Anyone here who have done the same? And did you get the same 5G download speeds ? TIA
06-10-2024 10:06 PM
Thanks for mentioning it. Too bad only too many rewards that will go to waste ☹️
06-10-2024 10:03 PM
Thanks. Very helpful 👍 I didn't know that.
06-10-2024 09:14 PM
There is no longer $15 plan for existing customers, the lowest plan is $19, which you could lose 240 GB free data.
some customer downgraded to $29 plan and still have their 240GB free data.
06-10-2024 09:11 PM
Also, the $15 plan is not available for exiting customers anymore. $15 plan is only available for new activations.
06-10-2024 09:07 PM
I wouldn’t do it because if you downgrade your plan. You will lose the 250gb of data.
06-10-2024 09:05 PM
@Bebet , if you downgrade your plan, that bonus data will disappear immediately. The condition for keeping that data available for 150 days requires you to stay on the existing plan.
