07-24-2021 03:59 PM - edited 01-06-2022 02:53 AM
I recently switched my number and provider over to Bell, and now I am unable to access my self serve account to cancel my plan. Is my plan automatically cancelled? If not how can I access my account?
07-24-2021 07:48 PM
@hayo13 wrote:I recently switched my number and provider over to Bell, and now I am unable to
Could you let us know the reason switching to Bell? Coverage is the same as Telus. Unless it is part of a bundle with better (cheaper) plan?
07-24-2021 06:26 PM
You already cancelled by porting out. What kind of phone did you get?
07-24-2021 04:38 PM
@hayo13 wrote:I recently switched my number and provider over to Bell, and now I am unable to access my self serve account to cancel my plan. Is my plan automatically cancelled? If not how can I access my account?
Didi you have a credit card that was registered on your Public Mobile account? If so, since your account is cancelled there should be no issues about future charged on it.
But in the event, a charge happens you can contact the Moderators to have removed.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
07-24-2021 04:05 PM
Once your number is ported out your account is closed automatically. Nothing to worry about.
07-24-2021 04:05 PM - edited 07-24-2021 04:06 PM
when switched to any carrier you confirm port your number. by SMS
Your reply should be: YES.
your public mobile plan automatically cancelled.
07-24-2021 04:04 PM - edited 07-24-2021 04:07 PM
@hayo13PM is prepaid service, you don't really need to "cancel" the account. As long as PM did not get the renewal money from you , account will be in suspended mode and will be cancel after another 90 days of non-payment
To make sure PM cannot get the money from you , just remove Autopay if you have that setup at the moment
you can either do this via 611 or My account
1. 611: dial *611, click 5 for Autopay and 2 for remove
2. My Account: get the My account access back via opening ticket with Mod.
try step 1 first , if it work, then you don't have to worry about My Account access
[update: reading via your post again, you already switched over to Bell.. then you don't need to anything.. you already ported out.. then account already closed.. ]
