06-26-2022 05:58 PM
Basically title. I switched to a $35/month plan from a $25/month plan but didn't receive my usual old loyalty program discount. I never opted for the new loyalty program with points, so I know it has nothing to do with that (hopefully). Also, something to note, I did renew my plan a little early (like 2 days before the usual renewal time) when switching, so maybe that had something to do with it? I also checked and I don't have any loyalty dollars added to my balance currently. Will my rewards be applied to my next month's plan?
Thanks in advance!
06-26-2022 06:23 PM
@Calvinhtr , off-schedule renewals do not result in rewards being paid out as mentioned above. You will get the reward on the next schedule renewal.
06-26-2022 06:15 PM - edited 06-26-2022 06:22 PM
@Calvinhtr When you get your thankyou for your payment text you should see your rewards applied there and then in your rewards section shortly after , if you don't I would contact customer service and inquire why they are not applied Click here
If you can't deal with Simon send a private message to CS_Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-26-2022 06:01 PM
@Calvinhtr did you click Change plan now? If so, I think it is normal. Change plan now will charge the full price of the new plan. Rewards should come back on the next renewal date
If you have clicked Change in the next renewal date and the plan was changed at the end of the last renewal, agree with what you clicked, check My Rewards to confirm if you still see all the rewards you are entitled to, like Loyalty reward or Friends referral
